How to disable copy / paste?
Hi Larry,
You cannot do this to Windows system however you can use an application or special software to disable the copy and paste function. Please take note that not all copy and paste software is a secure application because for some task manager and registry edit was also disabled and it will result to difficulty in terminating this application.
Please find below the list of disable copy and paste applications:
1. Prevent is a freeware application which runs on all Windows system. You can disable copy, paste, delete, copy to, move to, send to, renaming, and task manager function. Removing this program, you will need to uninstall it.
2. Ajent is a freeware that you can disable copy and paste function. Terminating this program is easy you will just to access task manager and end process Ajent.exe.
3. Stopper is a freeware that you can disable copy and paste function.
NOTE: There are many applications you can download from the internet so use it at your own risk.
Lilac
You cannot just disable copy, paste and other such functions in your Windows operating system as a whole, but as always, there are some indirect solutions to this problem. They consist in disabling these functions for specific applications.
To achieve this, you have to refer to RMS (Windows Rights Management Services).
