How To Disable The Firewall On My Computer?
I think my firewall might be interfering with my new software which I downloaded yesterday. How to disable the firewall on my computer?
Before beginning this answer, I would like to advise you that it is extremely risky to disable the firewall on your computer. It is there to protect you from potential threats. However, if it is indeed interfering with your work, here are the steps to disable it: First, you should open the control panel and look for the windows firewall icon. Click on it and you and wait for a new window of windows firewall to open.
You will see a toggle button showing you whether windows firewall is turned off or on. If it is on, you can turn it off by clicking on the toggle button. When your work with the software is done, make sure you turn it back on.
