How to disable ipv6 Windows 7 Operating System?
I am using Windows 7 which is configured to use ipv6 automatically. Is there any way by which I can disable ipv6 Windows 7?
Yes, We can disable ipv6 in Windows 7 by using the Network and Sharing Center.
Step 1: Press the Ctrl+R keys to open Run command and type “control”. Press Enter key.
Step 2: Select Network and Sharing Center to open Network and Sharing Center.
Step 3: Click on the connection link in the required Network to open the Network Status Dialog box.
Step 4: Click on Properties button and open Networking tab in the Properties dialog.
Step 5: Deselect Internet Protocol Version 6 (TCP/IPv6) option and click OK Button.
If you require to disable IPv6 in other Networks, follow the same steps for each Network.
