How to disable lync blink on Windows 7
Hello expert, I am using windows 7 ultimate version. I want to know how to disable lync blink. This work for my project. So I need the whole theory of this disable lync blink. Please suggest me some links or website to get some details about disable lync blink. Thank you.
Best Answer by Davidson Mudge
Answered By 40 points N/A #164126
If you want to disable lync blink, On your windows Operating system 7, There is a solution available or what you can do is , Download 3rd party software, Which is a disable lync blink at software informer. Now I'm sending you a couple of a link from there you can choose best possible way to perform your task.
LINK 1
LINK 2
Answered By 0 points N/A #164127
Hi David,
       As of now there are no registry tweaks  to resolve this problem, however there are work around on how to disable Lync from blinking. First, set the Lync window as always on top. Second, set your Lync software as DO Not Disturb. And third, avoid sharing Lync screen. These suggestions may not be the most intuitive, since Lync frame was designed to blink if there are any changes on it or if you have received new message.
