How to disable Microsoft antivirus without administrator rights?
Dear Asked Alamduet
What you have to do is to boot your PC in a safe mode and then use this removal link;Â
This link has the best tutorial and i recommend you to use. Â
All the best.
Morrison Jermaine
Hello Alamduet,
In my experience there is no way that you disable the Microsoft antivirus without administrative rights. The solution is straight forward. Log in as administrator and disable your antivirus. If you are using someone else's system then ask the person to log in as administrator and perform this task for you.
This is the only way to disable it. My recommendation is do not disable your protection against viruses and malware or spyware's. Disabling your antivirus will give the virus an open way to corrupt the system.
