How to disable my camera in Hp Laptop Model no g42
If it is an inbuilt camera then just going to the control panel then look for the device manager locate the camera, It should be under imaging devices. Immediately you locate it right click on it then click on disable. In future if you want to enable it again just follow the same steps then click enable.
Note that when you disable the camera no program will use it, consider your reasons before you decide to disable the camera. Otherwise at some point you will need to abandon your work halfway to move to the control panel to enable it again. If it is not an inbuilt camera then just uninstall it in the control panels in programs.
Hi Aradhanas,
I have read about the issue you have with your Laptop Camera which you want to turn off. I therefore want to share with you the steps to take to solve your current crisis.
1. Click on the “Start” menu from your operating system and navigate to the control panel.
2. Click on the “Control Panel” and then “Hardware and sound” if using windows 7 or “Hardware” if using Windows Up.
3. Click the “Device Manager Option” and navigate to “Imaging Devices”
4. Select camera from the under listed menu.
5. Right click on it and select “Disable” option from the menu
You can also use this method if the former seems long.
Right click “My Computer” icon and select properties.
Select “Device Manager” option.
Under imaging devices menu, select Camera.
