How to disable printer report?
How to disable printer report? Whenever I print there was a report on the last page of my printing process. Even if I'm just printing for 1 page it goes 2 pages including the report.
This is quite easy to do. Follow the given steps:
1. Go to top menu and click on the file.
2. From different choices click on the options a new window will open.
3. Now from menu select display.
4. Here an option will be given at Printed Document Properties.
5. Uncheck this option.
You are done with it. See image.
You can disable print report by taking this step in the word options dialog, uncheck the option "Document documents properties".
Notifications
