How to display active directory structure
Hi Friends, Does anyone know how to display active directory structure, Is there any tool for that, Please guide me. Thanks and Regards, David
Print Management could be used to view the active directory. It is installed by default on the computer running Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate and can be used through Microsoft Management console
 To install the Print Management snap-in on a computer running Windows Server 2008,follow the steps below
1. From Server Manager, use the Add Roles Wizard to install the Print Services role. This installs the Print Management snap-in and configures the server to be a print server
2. From Server Manager, use the Add Features Wizard to install the Print Services Tools option of the Remote Server Administration Tools feature. The Print Services Tools option installs the Print Management snap-in, but it does not configure the server to be a print server.
once you have installed the Print Management, management console could be used to view the active directory.
