Hello fellows,
How to display files in thumbnail? I just installed windows 7 starter 32 bit operating system in my hp desktop computer and still on the process of exploring all the new features. I came from windows xp operating system, I just want to know how to display files in thumbnail when viewing pictures?
Ericson Eric.
You can do following cases to display files in thumbnails:
– You should go to the folder of those files, you will see "Change your view" icon at the top right
– Click "Change Your View" icon, the select any options:
+ Medium Icons
+ Large Icons
+ Extra Large Icons
Thanks
Khoa Bui
Basically you have to check that the option "Always show icons, never thumbnails" is checked or unchecked.
Firstly, check when you tried to change folder option “Display file icons or thumbnails”. Have you checked the checkbox “Always show file icons or thumbnail”
Secondly go to the windows explorer and click on the Organize option at the top. Kindly Select Folder and search option. In the advanced setting under view option the first line will be "Always show icons, never thumbnails". Kindly, check that this is checked.
“JK”
