hasan4368
10 points
Posted on - 07/14/2011
I have a Photoshop Image (.PSD) file which is RGB type. I wrote a VB.net 2008 application for image viewing. Its work fine for JPEG/GIF/PNG but when I try to load the .PSD file I get an error. In my VB.net application I have a picturebox control.
How can I load a .PSD image into a picture box control in VB.net?
Balram
How to display PSD file in Picture Box in vb.net?
Hi, I recommend that you do not use .PSD files. This is a Photoshop file, not an image file. ".PSD" is the primary file extension for native layered Photoshop files.
The acronym stands for "Photoshop Document".
There is no way to display a PSD file in picture Box Visual Basic .Net
PSD files are Adobe Photoshop files which have default formats that are only suppoted by Photoshop features. However, one can use CC++ codes to import Adobe Photoshop files to any other projects.
sojol29
Psd file is a Photoshop file. It is not open of vb.net code. So you can download Photoshop then the psd file image edit the JPEG or GIF format then save the file and then the image file you can open vb.net.
