How to display watermark on xcart?
Is there an application or software that will automatically generate a watermark?
Some of my researches show that there is a possibility that this application exists but I don’t know how to discover it.
I hope you can give me a solution for this problem.
Thanks
Answered By 15 points N/A #185115
You wanted to download software to display watermark on xcart. There is some software on net. You can try V4. 3. X.
This version is good and may not give any headache to you on the process of installation and use. On web you may find many pages and links that shall lead you to such kind of download, but most of them are affected by viruses and malware contamination and not at all safe for your PC.
I tried to find some links for you that are secure.
Try them:
This process may also help you:
Also visit this link. This link may help you:
