Alan Farrer
10 points
Posted on - 01/23/2013
Hello Expert,
I have created many 3d models in *.max format. I am searching for free 3d max conversion software to convert my models. Tell me If you know about some free and easily available software with full features. It should convert Basic structure like *.3d or *.obj.
Thanks
How to do 3d max conversion?
3D Object Converter is a powerful tool that allows 3d model data to 3d file formats with accuracy and great quality. This software supports 468 file formats. You can easily download this converter from this website then you can convert your 3d max files to 3d format. You need to open this link to download this software.
http://www.brothersoft.com/3d-object-converter-68774.html
Hi Alan,
As we all know that .max model format is a closed one and if you have 3D Studio Max software install on your system you can easily transport or convert your desired 3d models into your choice .3d or .obj. If you are skeptical about this then you should be happy to know that you can download a free demo version of software mentioned above while clicking below.
https://usitility.com/download-3d-studio-max
Hope it helps.
Thanks
Baker
