How to do ad-hoc file transfer
I just wanted to know to do adhoc file transfer. we have 3 computers at our house, 2 laptops, 1 desktop all wired.
Hi Marizgarcia22,
This is possible with the use of the ftpadmin command. You just need to take note that all the computers must be able to ping each other. They need to be able to do that to make sure that they are able to communicate with each other.
You will then have to run this command on either of the computers. You need to run ftpadmin.exe. It will start to display the address you are listening to. You can then FTP to this computer from the other computer. After this, you can now use any FTP program you like or use just explorer.
Aristono
Since you have all the computers networked together, there are some things that you will need to observe so as you can be able to transfer files directly among the computers. They are the following:
-Lee Seen
