How to do exporting mms from iPhone?
I don't know how to do  exporting MMS from iPhone,
Please if someone can explain it to me here i would appreciate it
Hey Ann Tanner,
To get the SMS and MMS saved as a backup for further use you can use many third party applications. One of the best and trusted software is MobileSync . It can save SMS as well as MMS from your Apple phone.
Best of luck with your try and hopefully you will be happy after using it.
Hey Ann,
If you wish to back up or transfer your iPhone’s MMS and SMS, extract photo video and audio, print iPhone conversations,
To your Windows PC:Â http://www.backuptrans.com/download/exe/iphone-sms-mms-extractor.exe
To your Mac: http://www.backuptrans.com/download/iphone-sms-mms-extractor-for-mac.dmg
All you need to do is download and install the above application and connect it to your iPhone.
Feel free to ask if you need more help.Â
