How to do force format USB write protection
I want to Format my USB. As it is write protected, I am left with force format USB write protection option only. How to do this please help me somebody.?
You want to format your usb(Universal Serial Bus) flash drive or pen drive. But when you start formatting, it’s show a message; your pen drive is writing protected. I guess this is your problem, is this?
1.  Check may be your pen drive has any security switch for preventing data loss. Enable data writing by disable this switch.
2.  And the second thing that can be happen is damaging internal circuit and functions, which may cause of this kind of error message. It is not possible to fix internal problems.
Right click my computer and select manage and open device manager a find the USB drive letter. Right click properties choose optimize performance options click ok open my computer select format on flash drive choose NTFS in the file system drop down box device  formatting completed if format doesn't work with the USB device you must buy a new one.
