Hi Friends,
How to do Google position check, Will I be able to check the keyword position in Google ranking. Is it possible to check the keyword position for my own domains and competitor domains. Please advice on how and where to check Google position of a single keyword for many domains.
Thanks & Regards,
Ethan Jessica
To check for your domain ranking in Google by means of key word visit the following web address
https://moonsy.com/google-keyword-rank-checker/
Once in the website,
1. Type your key word in the text box given
2. Type your domain name in the domain text box
3. Click CHECK KEYWORD RANK
This website also allows you to also check the keyword ranking against competitor domains
Hi
You can do Google position check at this link:
https://www.searchenginegenie.com/google-rank-checker.html
It is developed by automatically query google search engine.
First it will check whether your typed url is available in first 100 positions are not.
If your url is in first 100 position.
It will the position of your url.
Procedure:
1. You have to enter url or domain name
2. You have entered the keyword or phrase you want to check
3. Select googles regional domain
Hope you got some need full
Hi there Ethan,
There is obviously a way to check the rank of your desired keyword in your domain on Google. For this you can visit the Google Rank Checker by Search Engine Genie. On visiting of the page, follow these steps:
1. Scroll down to find the Position Checker Tool
2. Enter your Domain Name or website URL
3. Enter the specific keyword for which you want to check the rank
4. Select Google's Regional Domain: this option searches for all the domains in the specified region and brings out your competitor domains.
5. Solve the captcha entry and write down the answer in the box
6. Click on Submit
After some time, the tool is going to show you the position of your domain according to the keyword you provided.
Hope that helps. Please don't hesitate if you need more assistance.
