How Do I Activate My Boost Mobile Phone?
I have recently bought a new phone. It is from the mobile company called boost. I have not started using it yet, because the activation process is incomplete. How do i activate my boost mobile phone?
It’s easy to activate your new boost mobile phone. I will guide you through the steps you need to follow.
First, open your computer and log on to the website given below:
https://activate.boostmobile.com/primary/activations-home
This page is specific to activating your phone.
If you already have an existing number which you want to now use with your new phone, select the second option, otherwise if you want a new number, choose the first option. Boost will then give you various options of going forward with your specific request. You will need to enter your activation information on the website.
If you find the website daunting, you can check whether you have a boost store near you and visit them physically. You can check the nearest store by entering your location in the website.  
If you are using Boost Mobile, you need to activate your phone or device first before you can use it. You can do the activation online. To activate your phone online, you need to have your ESN number. To try the activation online, go to the Activate a Device page and follow the instructions.
For brand new Boost Mobile phones, there is no activation fee if you activate the device using the activation PIN number included in the package. If you don’t have an activation PIN number, there is a $10 one-time reactivation fee. Certified pre-owned phones will also be subjected to the standard $10 one-time reactivation charge at the time of the activation but will receive a $10 account credit to offset the charge.
Notifications
