I have just started my online business. I'm planning to sell a brand of cosmetic products. Since the brand I am selling is new, I'm using my blogsite to advertise it. I want to monitor the reception of my potential clients regarding this new brand. How do I add live traffic feeds to my blog?
Hi betty! How's your business planning and advertising doing? Anyways, regarding your concern, there are lots of applications/programs that you can install and incorporate your blog to enhance your business strategies. And there are even free applications such as feedjit and ipmarker. You might also want to access google play store for your android phones. Goodluck!
Hello Cuthbert Betty,
I wish you all the luck in your business. Here is how you can add live traffic feeds to your blog.
The application is called FeedJit and here are the steps on how you can add this feed to your Blog:
First, sign up with FeedJit (Just fill out the sign up form) Hit Next.
Next page is where you can configure how your traffic widget would look like.
Feel free to choose the colors, size so as the widget would blend perfectly with your blog.
Once you are done customizing everything, Select your Blog page and from the FeedJit page you can add the widget to your site.
