Hello. How do I add a printer to my small office network? I have an HP PhotoSmart k510a with wifi 802.11n and a Linksys E2000 Advanced Wireless-N Router with simultaneous 2.4 GHz and 5 GHz Band. I'm on a Windows XP 64 bit system. Thanks.
How do I add a printer to my office network?
Hey,
To install the network printer at your office ensure you remember the name of your printer.
How to add a printer to the office network:
1.)Ensure your computer is connected to a network
2.)Click start>>Devices and printers.
3.)Click add printer.
4.)click add network,wireless and blue-tooth printer on the add printer wizard.
5.)Click the name of your printer among the available ones and click next.
6.)click install driver if prompted to and if admin password or confirmation is required provide them.
7.)complete the additional steps and click finish.
Firstly, if the machines are not already in the same work-group then set all the machines to the same work-group. You can also do this task from network wizard process.
Secondly, you need open the firewall exception for printer and file sharing on the computer with the printer. Right click the printer, set it shared. On all other Computers go to network places and browse to the computer with the printer. Double click the computer, you should see the printer. Double click it to install it locally.
