How Do I Backup My Computer Windows 7?
I have a windows computer which I have some important files on. I need to take a backup. How do i backup my computer windows 7?
It’s always a good idea to backup all your data, since there are a lot of things which can go wrong with your computer. There are many ways to do it, depending on your budget, types and size of files and whether you have an internet connection:
1. Flexible budget, large size, optional internet connection: If you have the mentioned constraints, you should think about investing in a hard disk. You just need to copy whatever files you need to the hard disk. Or, if you want a full backup, go to control panel and search for “backup and restore”. Click on it and you will see the option of “set-up backup”. Choose it. You will be asked to select your option. Browse from available options and select your hard disk.
2. Low budget, smaller size, good internet connection: You can use a cloud option for this. For example, gmail drive. Upload your files in the drive, and buy more space if you need. This option is safer than a hard disk drive because there are chances of the hard disk getting corrupt, but this data will remain safer.
I suggest using a combination of both the options. Use the second one for your most important files.
