How do I backup Windows XP theme?
Hi there.
I have just customized my Windows XP fonts and wallpapers.
How do I backup Windows XP theme that I made just in case I want to customize another theme?
My Windows XP is 64 bit.
Any help would be much appreciated.
Thanks in advance.
Best Answer by Green Barter
Answered By 0 points N/A #139566
Hi  Donna,
I have read your question, Here are some steps that will help you backup your themes in Windows XP :
Step 1 : Right click on desk top then choose properties.
Step 2: In the new window that opens up, your current theme will be selected by default, click on the Save As button.
Step 3: In the file save dialog that appears give your theme a name and save it to a safe location. Once you have saved the file a. Theme file will be created where all your settings will be saved.
If you want to restore your desktop to use a theme you have saved earlier, you can do that by choosing the theme you saved.
If the theme is not available in the list, you can click on the browse button and open the theme from the location you saved in.
Green Barter
Answered By 0 points N/A #139567
For Windows XP it is easy  to set the theme that you like and find favorite and you have just to follow the following tow steps:
1. Right click on you desktop (or screen ) with your mouse and then you will see this tool "Theme Settings":
2. Click now on modified theme and choose from the list the theme that suits you.
 Cross Bohon
Answered By 0 points N/A #139568
Dear Donna,
After read your question I have sort out solution for your problem. Here I intimated some steps to solve your problem:
First: Switch on your computer.
Second: Make right click on your desktop and click on properties option. Then go to theme menu and brows your selected theme.
Third: After that click on to "Save as" option. Then select a suitable drive of your computer and make a Folder and rename it.
Fourth: At last save your theme into that folder for backup.
So whenever you need your favorite theme you just select it for your desktop theme.
Jashim
Bangladesh
Answered By 0 points N/A #139569
You can do that in some simple steps.
First go to your desktop, right click and choose properties. There you will see a tab called “navigate to themes”, click it and a new window will open.
At that time, the selected theme will be your current theme. Click on “save as” to save the theme with a unique name.
Answered By 0 points N/A #139570
Hello Donna, Windows XP themes are not as complicated as for other OS like even windows 7. With Windows XP its not really complicated to back up your theme.
In a case a modification was done by some body and you one to get back your old theme, just follow the steps below; – Right click on you desktop and chose properties – The box that appears directly on the themes tap and besides it is an option to save it. – Just click on the save and always try to save it on any other drive apart from your C drive so in that case you are guaranteed you cant loss it even after formatting.
Hope that helps Donna.
