How do I break photo in pieces using Photoshop?
I have a panoramic JPEG image that I would like to break in several pieces like a puzzle.  I have Adobe Photoshop CS6 with the Adobe Mercury Graphics Engine.  How do I break photo in pieces using Adobe Photoshop CS6?  I run on Windows OS 8 it that matters.  Any tips or suggestion?
Answered By 5 points N/A #198560
Process for making puzzle in Photoshop is very easy. I will give you simple steps and if you want more you can go on the link above. First open your image in Photoshop, then duplicate your background layer (Ctrl+J) and rename it as Puzzle. Add a new layer under the duplicated layer and fill with black. Now select the Puzzle layer and go in Filters > Texture > Load Texture and find your Puzzle.psd effect. Play with adjustment texture options and click ok.
For making more interesting puzzle effects go on the link below you have tutorial how to make Puzzle Effect in Photoshop CS3. It’s the same for Photoshop CS6. This tutorial is very detailed explained and will teach you step by step how to make on your image a great puzzle effect. Here is the link that you should look at: https://www.photoshopessentials.com/photo-effects/photoshop-puzzle/
If you can’t find puzzle effect in your CS6 then go to this link and download Jigsaw puzzle effects for Photoshop and PS Elements.
Williamson Mellisa
