Hi guys. I just purchased a used Nintendo Wii with the PowerPC CPU, ATi GPU, 512 MB internal flash memory and Orb installed. How do I cast movies on Wii Orb? I was hoping to stream a video in Divx format. Thanks guys.
You will have to create an Orb account and then follow the instructions below to set up your Nintendo Wii game console.
The current Orb users who have already installed Orb on their PC need to be running Orb version 2.00.0856 or a newer version. To check your current Orb version, click on the green Orb tray icon on your taskbar and select about…
1. Connect the Wii to your TV.
2. If you do not have Opera browser, go to the SHOP channel on the Wii and download it. The Internet Channel will be added to your main Wii menu when the download is complete,
3. Select the Internet Channel from the main Wii menu. Type in this address “mycast.orb.com” into the Opera Browser, and enter your Orb login and password.
4. You’re done! Your Wii can now stream media from your PC to your TV. Be sure to leave your PC turned on in order to access the photos, music and other media.
