I recently installed txtreader version 1.7 for my iPad mini iOS 4.3 so I can upload and read a local TXT file (UTF-8). Problem is, language is in Chinese. Is there an option to change language in txtreader for iPad mini?
How do I change language inTxtreader for iPad mini?
Of course sir, you can change the language. Go to the settings page:
And after settings dialog shows find English language and change it. TxtReader supports English, Chinese (Mandarin) and Japanese. I hope I helped you.
Regards.
Hi John,
Not to worries. Your problem is simple. First open TXTREADER. Then you can see four options. As you are saying the language is currently Chinese you may not understand the language, so just select the last one, and that should be settings.
After selecting that you can easily see the language. Just change the language into English. You are done. Immediately your language will switch to English language.
Good Day.
