I'm using Mdaemon Messaging Server on my Blackberry Z10 LTE. The security is a superb proactive protection against spam and viruses. I have Mdaemon 13 and I was wondering if I can change Mdaemon skin for a personalized effect? Thanks.
How do I change mdaemon skin in Messaging Server?
Hello Yelverton Nolan,
I read about your question, and I think the best way can help to you is to give you  links where you all necessary information is in one place. At this link you will find general things for MDaemon and here you will find how exact things for you.Â
Hopefully I could help you.Â
Regard!
Nathan H Underwood
I think the best way to help you on this one is, to give an alternative in which you will be able to access a complete guide in use of this software, from its installation to all forms of its configuration.Please follow this link to get this resources.
http://www.altn.com/Support/eLearning/
Hope it helps.
