How Do I Change My Default Browser?
I am filling some official form, and it is asking me to fill the form by some specific browser. How do I change my default browser?
Many governments forms are required to be filled by a fixed web browser. So, here are the steps to change the default web browser:
1) Go to Settings.
2) Go to Apps.
3) Move to All tab, look for your default browser and tap on it.
4) In the Launch by Default, section click on Clear Defaults.
5) Now open the link, it will ask you for a browser, select the one that suits you.
Depending on your requirements you can set the new default browser.
The Microsoft Internet Explorer is the default browser of Microsoft Windows. If you want to remove this and change the default browser to a different one, there should be no problem. Changing the default browser used by Microsoft Windows can be done in two ways: from the Control Panel and in the settings of the browser you selected.
To try the first method, click “Start”, “Control Panel” then “Default Programs”. On the next screen, click “Set program access and computer defaults”. In “Set Program Access and Computer Defaults” window, click “Custom” to expand. Under “Choose a default web browser”, select the browser you want and click “OK”.
To try the second method, start the browser you want to set as default like for example Mozilla Firefox. Next, in Mozilla Firefox, click “Menu” then select “Options”. Alternatively, you can enter without quotes “about:preferences” in the address bar then hit Enter. In “Options” tab, under “Startup” section in “General”, click “Make Default”.
