Hey guys,
I was just wondering if there was any way of changing the save format of a webcam from avi to mp4 or something smaller. I'm using a a4tech webcam and I'm using HAmcap webcam software. After taking the video I convert it into a mp4, but this is taking too long just to convert the videos. Do you guys have any suggestions on how to do this?
How to Convert AVI to MP4 files from my A4Tech Webcam
Today I am going to tell you, how to change the save format file of a webcam from avi to mp4. Please follow the instruction. There are two way to convert the webcam format file. First one is from online and second one is third party software like (Total Video Converter). It’s also pretty good.
Hope I helped you out.
kevin11
First you check the requirement of your webcam and look what features it has. Read the features of driver of webcam. Is its videos are compatible to convert to some other type or not. If it can be converting then install the updated version of webcam driver and then you can convert videos by some external software.
You have to search for good software like Camera webcam and make sure that your system is compatible for that software and in how many types it can convert. After that install it and follow the instructions to convert your videos.
Well If are looking to change the format of a video from one format to another like (Avi to mp4) all you need to do is go to http://download.cnet.com/windows/, search for a good video converter. After searching based on the reviews given by users select the best one possible. Download any one of them and install it in your PC. Now that it has been installed change the format of all the videos you want to any format available in the program. I hope that solves your issue.
