How do I change the video format form MOV to AVI?
1- Search for a free video converter software or you can download the best one called format factory
2- Choose video format that you want to convert to
3- Add the files that you want to convert it
4- Convert it and save to the place you want
5- Burn your DVD and enjoy .
Hai Mokai2008,
If you want to view .mov file videos in your DVD player, you may have to convert it to a .mp4 format. Well i recommend you to download a video converter called Total video converter. Total video converter supports various types of file format like .mp4, mp3 avi etc and with this you can convert any video file format to any other video file format.Â
Total video converter supports the following files.
