How do I check SharePoint site disk space usage?
Hi Eduardo
In order to check how much disk space a SharePoint site is using you must be a Site Collection Administrator or owner.
Hope this helps !
Arseno
Hello Thomas. To check the disk space of a site using MS Sharepoint, follow the following steps:
1. Click on Site Settings.
2. Click on Go to the site admin.
3. Click on View Site Collection Usage Summary.
4. Then go to View Storage Space Allocation. This will show you how much disk is being used.Â
There is an option for Sharepoint user, that is you can buy more space and have other upgrades. This will help you to use more space and make new sites. A sql server stores all the image, text and other files.
So obviously the disk space is a concern for the user. So by checking disk space you can calculate how much more space do you need and take proper steps.Â
