anonymous
7060 points
Posted on - 11/17/2011
Hi! I have several files in my PC that I no longer need. But I was skeptical which one to delete or not. I am looking for a free software that can help me delete the unwanted files automatically. Can someone please help me? Thank you.
Clean up my PC from Unnecessary Files
You can use the disk clean up option to delete files safely and free more hard disk space.This option can be used to clean up listed items like removing temporary internet files,emptying out the recycle bin,programs that you no longer use, etc.All of the items can be deleted or you can choose the ones you want to delete.Its up to you.You will find this option in My Computer>Properties>general>Disk Cleanup.Put a tick on the items you want to delete and click OK.You can also click on the "more options" button for further options on this.
Hi.
You can use Revo Uninstaller Pro to delete all your unwanted programs. It is also capable of deleting programs that you cannot delete on your Control Panel's "Add/Remove Programs”.
It is fast and powerful tool for uninstalling and removing programs. Revo Uninstaller analyzes the application before it uninstalls the program.
It also has a feature of Force Uninstall when you have problems on removing stubborn programs such as programs that are not listed or programs that are partially installed.
Best of all, you can monitor the process of uninstallation. Try it here.
