How do I clear the browsing history of my Internet browser?
Dear friend,
Whenever one browses the internet, the computer subsequently saves the sites visited by the user. How to remove these histories varies from MS internet explorer, to Mozilla Firefox, to Opera, to Netscape, and also the Safari users. For the Mozilla Firefox, press the CTRL + Shift + DEL buttons simultaneously. This will open the window that requests for clearing of the history. Another option is to go to the Tools menu and select the Options button. Next is to click on the Privacy option and then the History button. Finally you can click the Clear or the Clear Now button. Then your history will be cleared.
Regard!
Hi Natalie Wright,
You didn't mentioned about the version of Firefox that you are using. Options may vary from versions to versions.
However I will post a way to solve the problem.
1) Click tools.
2) Go to options.
3) Click on the second tab 'PRIVACY'.
4) Then click 'CLEAR BROWSING HISTORY NOW'.
5) Then click 'OK'
In some other versions the 'clear browsing history' can be seen under privacy tab.
Hope these helped you to clear the browsing history on your Mozilla Firefox browser.
Hi Natalie Wright
Check out below Techyv post too because this post is also addressed your problem and from there you will get huge information regarding on your issue.
Notifications
