Louise Rios
10 points
Posted on - 02/08/2013
Can I combine pdf file by dos command? I'm trying to merge pdf files into a single pdf document then transferred and printed. System specs of my pc are: Pentium 4 2.66 GHz, 2G RAM, OS Windows xp 64 bit. Can someone please teach me?
How do I combine PDF file by dos command?
If you have access to the Internet, I suggest you go to a certain Norwegian website for the type of processing that you say you need to perform. Once the first page is uploaded to that website, you can use the Append feature offered by the site in order to add more pages, one after another. Once all pages are added, then finally the Save option will generate a single PDF file containing all your pages. You can then simply download the single pdf file to your PC. Here is the link.
I am also attaching a snapshot image of the website. Hope it helps.
Best Regards,
Parisi
