How do I compress or make files into one file?
Microsoft Windows XP and later users.
Users who are using Microsoft Windows XP or later operating systems can compress files using the included compression utility by following the below steps.
If done successfully, the computer should create a .ZIP file with the name of the file or folder you right-clicked. For example, if you right-clicked on a file named todo.txt, the compressed file with that file and any other file or folder selected would become todo.zip and be located in the same directory.
Microsoft Windows XP users can also use third-party compression utilities and online services.
Microsoft Windows 98 and earlier users
Because other versions of Microsoft Windows do not come pre-bundled with their own compression utility, it is up to the user to install and use a third-party compression utility. Before following any of the below steps, you must download and install one of these utilities.
Once one of the compression utilities has been installed on the computer, you can use it to compress and combine multiple files into one compressed file. Below is a basic example of how this could be done.
In addition to the above suggestions, users can also often open the program through Start/Programs and add the files manually through the program itself.
Linux users
Unlike many other operating systems, almost all variants of Linux and Unix come pre-installed with some form of command capable of compressing and uncompressing files. Linux and Unix users are likely to be dealing with file extensions such as .TAR, TGZ, .Z or .TAR.GZ. See the below Linux and Unix command pages for additional information about the commands used to create compressed files and to uncompressed files.
gunzip
pack
tar
uncompress
zcat
Please check in your system you have Winzip or WinRAR software's are installed or not.
In general Winzip is a default software along Microsoft Windows (any version). Make all the files you want to compress into single folder.
Right click on the folder select 'send to' option there we can found compressed to Folder or Winzip.
Select it.
Hello Ernie,
To compress you files into a single fie, you can use a software that is called winrar, which you can get for free from the internet. Winrar is used for compressing and archiving RAR and Zip files. You can download it from the following site:
www.win-rar.com/download.html
Once you have downloaded it, install it on your computer. Collect all the files that you want to compress and put them in a single folder. Right click on the folder that has the files and choose Add to Archive. Choose the destination for the archived file and give it a name. Click OK. Wait for the process to finish.
Your files will have been compressed successfully.
Regards
Lee Hung
In order to make several files into one file, you have to install any good file compressor software.
Here, in this techyv page, there are many good compressors described.
