I was reading that Windows XP can send faxes without an external fax machine. I no that Winxp fax service command line is not installed automatically, so what are the commands I would use to configure winxp fax service command line to send, track, receive and monitor faxes?
How do I configure Winxp fax service command line?
Hi Robert L Hammon,
The basic requirements in sending a fax data is that you should have an internet telephony connected from your computer to your telephone line and also, with fax modem too (attached below is an example of a fax modem to withstand the bandwidth that will be required in sending files via fax messaging), with this, you are all set to install the fax service offered by windows xp.
