How do I convert APK to FLA without lost data?
How can I convert Android files to Flash files? How do I convert APK to FLA? I may need to backup my files first, provide detailed assistance. I am using Windows.
Hello Chet Dambaugh,
There are several software to convert such as SID FLV player, any FLV player, Media menu producer etc from which you can convert your android files to flash files or flash files to android files. The best converter to convert APK to FLA is Max unit converter. It is very simple to use and most comprehensive. It comes with full calculator. It can convert in degree, angle, energy, length, metric, power, pressure etc. Just download the software then install in your pc and follow all instruction. It’s very easy to use.
Thanks,
Akerly Joqw
