How do I convert dat to video clip?
Hi there.
I have a lot of VCD DAT files that I would like to convert to video clip segments in MPEG format.Â
I'm on a Windows XP 64 bit sp2 system.Â
Can someone teach me to convert DAT to video clip?
Hi there.
You can try one trick which my work, change extension of your file from .DAT to .MPG and see if it works.Â
If not, then try this application:Â http://www.ojosoft.com/download/download-total-video-converter.html
It is very powerful application which will easily convert any file to any file including .DAT to .MPEG
You can find more information on link which I provided.
I hope I helped.
Regards.
HI
You can try this also there are so many free software which can convert file format from one to another format like sound forge, total video converter no need to search for its patch because it can convert 50 files with its trial version so search complete your job.Â
I am sure this will work for you. Â Â
Thanks
