Hello Mac Users. I started using Mac recently and came across PKG Zip files. I am used to and like ISO files for all my images. Anyone who knows how to convert Mac Zip PKG to ISO file? The main reason I want to do that is because I am not able to open the PKG zip files. Thanks a lot in advance for your assistance.
How do I convert Mac Zip PKG to ISO file?
Yes there is such a software that can convert Mac Zip PKG to ISO. You can download and install AnyToISO to open, extract and convert your files. This converter is available for both Windows and Mac PC and is capable of extracting or converting NRG, TAR, CDI, ZIP, IMG, CDI, PDI file format and more.
The “PKG” file format (.pkg) is a file format or extension normally used in Mac OS X operating system. The file normally contains installer scripts used by a variety of Macintosh programs for installation purposes. There are also times PKG files are used to update NeXT installer packages. This file format was developed to help software designers create uniform installer applications.
It allows the easy and seamless installation of software applications and software updates. If you have several PKG files that you need to convert to ISO format, you can download AnyToISO. This software allows you to extract and convert any disc image to ISO format. It also allows you to create ISO files from CDs, DVDs, Blu-ray discs, and folders.
Among the supported file formats include:
- 7Z
- BIN
- DAA
- DEB
- DMG
- IMG
- ISO
- ISZ
- MDF
- NRG
- PKG
- RAR
- TAR.GZ
- TAR.BZ2
- XAR
- ZIP
