How do I convert PDF to Excel file?
I have a huge amount of PDF files and I want to convert it to Excel Sheet. However, I do not know how to convert PDF to Excel file. Can anybody tell me how to convert PDF to Excel file?
Thanks
Tony Bailey
Best Answer by Pratu Santr
Answered By 0 points N/A #135971
I have read thoroughly your problem of converting pdf to excel file. You said you have huge amount of pdf file to convert it to excel. There are many online converters available to convert pdf to excel file. Here I can name some of them-
  • www . pdftoexcelonline . com
  • www . pdftoexcelconverter . net
  • www . pdfexcelconverter . com
These websites are for small amount file. For mass conversion you will need a software. Some software in net are found easily. Some of them are free and some are required to pay. In Cnet.com you will find software for conversion free trial. The name is Pdf to Excel Converter. Size is 4.15mb. Hope this information will help you.
Answered By 0 points N/A #135972
Let me first know what the type of data in PDF file is. The data may be easily convertible to the text format.
Then do this.
1.       Open the pdf and then copy the text that is in it to a simple text file. Thus you have the data.
2.       The second is that the fields must be separated by a delimiter.
3.       Open the Excel application. And there you shall find the import option that imports data from the text file. You will need to specify a delimiter by which you can separate all the columns of the text.
4.       Next save the excel file.
