How do I convert youtube to ipod mp4?
Hi there.
I would like to convert flv video files to mp4 files so I could store it on my iPod.
I have the new 16 GB iPod Nano with Bluetooth.
Can someone suggest a software or program to convert YouTube to iPod mp4?
Best Answer by Fraserr Dawn
Answered By 0 points N/A #172736
Hi there,
There are lots of file extension converters that you can find and download.
You can use the Media Converter or some free Online File Converter.
But if you want the YouTube Converter, you can download it in this site: it is a YouTube Converter & Downloader.
You can convert not only .flv files to mp4 files, but also other file format types like .mp3, .avi, .3gp, mov and many more.
Hope it helps.
Answered By 0 points N/A #172737
Hello Martha,
You can easily convert any file format to your desired format with Any Video Converter software, which can be downloaded by Any Video Converter website. To convert the file, please follow the steps mentioned below:
1. Download the software from the link mentioned above.
2. Install it and open the software.
3. Click on Add button to add your file which you want to convert.
4. From the output tab on the top right screen, select the MP4 format.
5. Click on Convert Now button.
This will convert your file.
Thanks
