doriswneil
50 points
Posted on - 05/28/2013
Hi. I need help with PowerPoint. How do I copy a PowerPoint 2010 design and paste it in another template? I need this to save time instead of starting from scratch. I use Microsoft PowerPoint 2010 on Windows 7. Thanks in advance for the help.
How do I copy PowerPoint 2010 design?
Hi Doriswneil,
To copy a power point design, you just have to click the design, wait for it to be emphasized and then click ctrl + C, after which, switch to another design that you are planning to import the copied design that you have just did on the other window and press ctrl + V or the paste function, after pasting it, power point will allow you to move the design at your ease.
