How do I create image ignore bad sectors?
Hi there. I have a 1 TB Western Digital HDD. I want to create an image but ignore the bad sectors for backup. Is there a software to create image ignore bad sectors? I'm on Windows 7 64 bit. Thanks.
Hi
Have a nice moment! Thanks for your question some floppy disks use protection schemes that do not rely on bad sectors and might not work. Your question was there a software to create image ignore bad sectors. My solutions are that follow the link or below instructions.
I hope it will be solved your problems.
To open a command prompt:
Enter 'Y' if you receive the 'schedule this volume..' message.
Best of luck.
Thanks
