How do I create a multiboot ISO in a USB drive?
Hi.  I would like to create multiboot ISO in a USB drive that will contain multiple operating systems and diagnostic tools.  How do I create a multiboot ISO?  I'm on a Windows XP 64 bit sp2 system.  Any help would be much appreciated.  Thanks in advance.
Answered By 0 points N/A #137726
XBoot is an application that is designed for creating multi-boot ISO/USB from a set/group of ISO image files. XBoot has some websites where ISO files can be downloaded and which you can use to create a bootable usb/set of ISO image which can be burn on optical disk.
All what you will need is to drag & drop the ISO files from your computer to the software.
Here is the link to the XBoot https://sites.google.com/site/shamurxboot/download
