Hi. I'm trying to create a seamless wireframe object in 3D and 2D. How do I make seamless wire frame textures or is there a program for this? I'm on Windows 7 64 bit. Any help would be much appreciated. Thanks.
How do I create seamless wire frame textures?
Hi Simon,
Hope you are well.
There are several software available in market who helps you to create seamless wire textures. I am mentioning here one of the famous that I come across and that Mock Flow. With Mock Flow you can work from any where and it supports you to create seamless wire texture. Sharing the link for Mock Flow for your assistance:Â https://www.mockflow.com/
Hope this will help you in your project.
Thank You.
