Hi. I'm on a Windows XP 64 bit sp2 system. How do I create system state restore USB flash drive? I have the 64 GB SanDisk Cruzer USB Flash Drive with SecureAccess. Anyone know this? Thanks in advance.
Hi there,
System restore state is a mode where you can backup your file to a specific drives but it only works on a server type pc, to do this just follow this steps go to start then to administrative tools, the Windows Server backup after that click recover. This will open the recovery wizard on the getting started page, press next then choose another server then you can now choose what drive you want to place your data. Hope this helps.
