How do I customize Google hourly updates?
Can I insert an administrative template in gpedit.msc so I can edit the auto-update period? I'm having trouble with the report not getting updated hourly. Can I customize Google hourly updates?
For inserting Administrative Templates click on Start, then choose Run. Type in the box:Â regsvr32 gptext.dll . You should get this message DllRegisterServer in gptext.dll succeeded.
About customizing Google hourly updates you should see this website:Â
https://googlesystem.blogspot.co.uk/2009/05/customize-or-disable-google-update.html
Google Analytics will help you with hourly reports and new look.
I hope this will help you!
Williamson Mellisa
Hi Joshephadamm,
There are several ways through which you can customize Google hourly updates
Solution 1: Change the settings of Policy Editor
1) Navigate to the 'Local Group Policy Editor'
2) Go to 'Settings', select the 'Auto-update check period properties' option
3) Select the 'Enabled' option, set the value for minutes between update checks
Solution 2: Edit the registry key values
1) Navigate to the registry 'HKEY_LOCAL_MACHINE|SOFTWARE|Policies|Google|Update'
2) Add the two DWORD values as 'AutoUpdateCheckPeroidMinutes' and 'DisableAutoUpdateChecksCheckboxValue'
3) Set the value of 'DisableAutoUpdateChecksCheckboxValue' to 1 if we want to disable and 0 if we want to enable
4) Restart the system after the registry values are changed
