How do I delete Adobe worm on Mac?
Hi there. I have the new iMac with OSx Mountain Lion. A notification popped up that said I need to update Adobe Flash so I clicked update. After the update, I performed a security check using Norton Antivirus and it detected the Adobe Worm Virus. I think the worm disguised itself as the Adobe update and Norton cannot delete it. How do I delete Adobe Worm on Mac?
