How do I delete Google history files?
Hello members of Techyv.  I use Google as my web browser for my internet use.  How do I completely delete my Google history files from the beginning?  I'm on a Windows XP 64 bit SP 2 system if that matters.  Thanks in advance.
Best Answer by Huffman Serafin
Answered By 0 points N/A #198530
Hi Donna Davis,
Deleting Google History is very easy, first you have to go to the three-bars horizontal buttons below the close button of Google and click it, and click the History, or press ctrl + H, after viewing the History of your browser, the button that you are finding is obviously seen at the top of the page, click the clear browsing data of the History and you're good to go.
Answered By 5 points N/A #198532
Hope you are doing fine. By know I am positive that you have tried doing this the manual way, which is the tool just below the exit icon of the browser. Well you can fix this problem by downloading and running PC Cleaner.
This software will allow you to delete any type of private data on your computer.
