How do I delete Icons from the Doc In Mountain Lion
I know this should be quite simple but I am a quite simple person.
How do I delete Icons from the Doc using mountain lion.
Here are a few ways to delete/remove dock icons from Mountain Lion:
1. Click on the icon that you want to remove and drag it away from the dock by holding your mouse button down until a little “poof” cloud will appear on the lower right. When that cloud icon appears, release the mouse button and this will remove the icon from your dock. Or,
2. Drag the icon to the trash. Or,
3. Right click on the icon, hover on Options and then click “Remove from dock. ”
Hope this helps.
Hello Ruth,
To get rid of an item from the Mac OS X Mountain Lion you just need to do the following two things:
The following images illustrates how to go about that procedure:
Carl
