How do I delete LogMeIn history?
I use the free version of LogMeIn for accessing computers on my network remotely via SSL.  How do I delete LogMeIn history using a script to remove fragments of the program?  I'm on a Windows XP 64 bit system.  Thanks in advance.
Best Answer by Joseph Sons
Answered By 0 points N/A #141054
Hello Doriswneil,
Deleting history of LogMeIn have a lot of solutions. But let me give you the best solution for your problem. Here's a script on how to delete the LogMeIn history.
Kindly go to this link LogMeIn and you will be directed to the website where you can find the script that you're looking for.
You may also download my script attached file here.
You may now go ahead and work with the script.
Answered By 0 points N/A #141055
Good day. LogMeIn History is easily removed from your computer. If you delete LogMeIn history using a script to remove fragments of the program, you should follow the website where you get details.
Go to the link.
Best regards
