Hi. I would like to embed 3gp video clips on a website that is optimized for 115×65 mobile phone viewing. Can someone teach me how to embed 3gp to html for mobiles? Any help would be much appreciated. Thank you.
How do I embed 3gp to html for mobiles?
Hi Cynthhia Brown,
There are two ways to make to embed 3gp to HTML for mobiles. One is creating your own,and another is now you can get software or websites where you can make code by software.
Creating your own: If you search on Google there you will get many free code just copy and paste at your websites. You should just copy and test them is it working or not.
Here I am going to give you a code, you can try this but I am not sure it will work 100%. Confirm that you have a plugin in your browser it there are not browser will automatically want that.
Then just download that and try again.
Code attached-
In this code I set your desirable height and width. Other option and tag you should change to check out it.
Another way: Just visit the web link which is given below then drag a 3gp video file and get a code.
Here you will get both versions Windows and MAC.
Best of luck
